Engine stalls
Old Jul 13, 2016
Dennis.Roper's Avatar
Dennis.Roper is an unknown quantity at this point
Engine stalls
My 2002 civic LX will run for a bit, sometime 2-3 hours and then it starts to hesitate and finally stop. It acts like it runs out of gas. No check engine light but did pull codes. Only one P1298 which is Electrict Load Detected Circuit High Voltage. My son just purchased car and ran the fuel tank to total empty. After filling it the next day this problem started. It sounds just like it starving for fuel, any suggestions? Thanks
Old Jul 13, 2016
metron's Avatar
metron is an unknown quantity at this point
Re: Engine stalls
Possibly may have overheated the fuel pump causing the intermittent failure. Or, sucked up debris from bottom of tank into the fuel filter, clogging it. I would do cheapest fix first, change the fuel filter.
Would a defective fuel pump/fuel filter cause the P1298? Could be a coincidence that it came on at around same time as running out of gas. Might be worth changing out the ELD ($20-30 bucks on ebay) and run the idle relearn process.
Old Jul 13, 2016
Re: Engine stalls
Thanks, just got the car home. I plan to pull the fuel pump/filter in the morning. I appreciate your comments.
Old Jul 13, 2016
Re: Engine stalls
P1298 is unrelated to your stalling complaint.
You can buy just the ELD if you want to fix that code.
Old Jul 14, 2016
Re: Engine stalls
Engine want start. Getting good spark at all plugs. No sound of fuel pump. Fuse is good and relay has a click when key is turned on. Tried spraying starter fluid in carb and would run until fuel was out. What should I trouble shoot before getting into fuel pump? Thanks anyone!
Old Jul 14, 2016
Re: Engine stalls
Pulled fuel filter out of tank and found a broken wire. Anyone know how to secure the two wires that will be soaking in the gas tank in a safe manner?
Old Jul 14, 2016
Re: Engine stalls
That's certainly unusual.
I might use a butt connector, crimped--- if the sheath won't melt in fuel.
Or solder the wire together (carefully, don't blow yourself up)
Old Jul 15, 2016
Re: Engine stalls
Repaired wire and did a test hooking power pack directly to pump to see if it would come on. It basically went with a quick hum and then stopped. I would have thought it would at least hum and stay on. I'm just not sure the pump motor is good. Perhaps the broken wire caused it to overheat until it broke-in-to. Anyone had good luck buying a used pump? I think the Honda pumps are better than the aftermarket ones. Any suggestions for a good pump to buy? Thanks
Old Jul 15, 2016
Re: Engine stalls
Hondas pumps have been stupid reliable IMO. I'd chance a used one as long as it hadn't been sitting in varnished gas for years. Hope for less than 100,000 miles on it.
Old Jul 15, 2016
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
Re: Engine stalls
The question I have is; how does a wire just randomly brake with no external influence? There is nothing moving around in the tank for that to happen.....
Was the wire perfectly split? Was it gnarled apart, like something chewed it apart?
Are you sure you have the correct fuse type in the fuse box for the pump (I think it is #17, under the dash?)? Did someone replace it with a high amp rating because they were having a problem with the fuel pump too?.... Could your ELD problem be somewhat related to the fuel pump for this reason?
If the pump is seizing and drawing a ton of current and you have the wrong fuse in the compartment, theoretically, this could cause a wire to break apart, acting a fuse, which it should not be doing....
I always ask myself.... WHY did it happen? So you can stop it from happening again.... I might be completely wrong here, but you should check...
Old Jul 15, 2016
Re: Engine stalls
Thanks for the comments. My problem now is getting the pump in and the ring around the top. The rubber seems so tight that it want fit in the opening. It did come out, so I know it should go back in. Anyone had a similar issue and how did you solve. I have to o get the pump back into the tank. Any suggestions would be helpful.
Old Jul 15, 2016
Re: Engine stalls
Dip rubber gasket in the fuel.
Insert gasket in top of tank
Carefully slide pump into top of tank through the gasket
note and mark where the first thread begins on the threaded ring, and mark the first thread on the tank so you can align those and spin the ring on.
Make sure pump housing is correctly aligned before ring gets tight.
threading the ring can be a PITA even with the correct tool.
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
NewHondaCivic
Nov 9, 2015 01:17 PM
chilling_pete
Nov 5, 2015 10:05 PM
damahark
Oct 28, 2015 08:11 AM
R Steele
Oct 22, 2015 05:09 AM
