04 DX cranks but doesn't start
Old Jun 23, 2016
jasonle88's Avatar
jasonle88 is an unknown quantity at this point
Hi all,
My civic cranks but doesn't start. I found out that my timing belt was snapped so I replaced that along with the water pump. I made sure that crank and cam was at TDC before putting everything back together. When I tried to start it up though, it still cranks but doesn't start. I noticed that my odometer would go from reading the mileage to showing all 0s and sounds as if it's dying.
I was wondering if it could possibly be my starter that went out?
Old Jun 23, 2016
Re: 04 DX cranks but doesn't start
Compression test.
Old Jun 24, 2016
mikey1's Avatar
you have bent valves as a result of the timing belt snapping
Old Jun 28, 2016
jasonle88's Avatar
I got my car to start but it's running a little rough. When it's in 1st gear, it'll only go up to about 15mph before it sputters so I'll shift to 2nd and it'll go up to 30mph before it spuuters and won't go higher unless I shift to 3rd. Could it be because I've had a tank of gas 3/4 full and it's been sitting out for about 6 months?
Old Jun 28, 2016
Got compression?
Got fault codes?
Timing incorrect?
No, 6 month old gas shouldn't cause something running that bad IMO.
Old Jun 29, 2016
mikey1's Avatar
did you even read my reply?
Old Jun 29, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Timing belt needed replacing at 105,000 miles or 5 years ago.
01candycivic
18
Apr 3, 2008 02:53 AM
crazyasian
Apr 26, 2007 12:05 PM
jta
Nov 2, 2004 11:49 AM
civicer
Aug 12, 2002 08:45 PM
