possible timing mess-up
Old Mar 31, 2008
01candycivic's Avatar
01candycivic is a jewel in the rough01candycivic is a jewel in the rough01candycivic is a jewel in the rough
so i put a new timing belt on and water pump on and this is the sound i get. i checke and made sure that it was tdc i think i jumped timing. and it sounds like i have cricket in my motor i need some help here
http://www.youtube.com/user/01candycivic
Old Mar 31, 2008
tfnaaf's Avatar
BLDNPSI Mod
Re: possible timing mess-up
Was that a CEL on the dash lit up?
Old Mar 31, 2008
pheaton's Avatar
A descendant of 2k1civic.com
Or the belt isn't tensioned properly?
Have you driven it? Do you have a power loss?
Old Mar 31, 2008
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
sounds like your alternator/ac belt or power steering belt is not tight enough. more than likely you alternator/ac belt cause it's a lot harder to reach the tensioner. They tend to make a chirping noise or a squealing noise.
Old Mar 31, 2008
greeen01civic4d's Avatar
if timing was out, ud have a looooot more noise than that, i mean a lot, it would be knocking a crap load, and probably lock up
Old Mar 31, 2008
my belts are tight. so no one thinks i jumped timing?
and is it safe to drive... it drives fine intill i hit vtec then i starts wanting to die one me.
Old Mar 31, 2008
here is some more sounds
http://www.youtube.com/watch?v=w3Mc1Ws1q3A
Old Mar 31, 2008
1. have u checked your oil level??
2. check out the CEL, it will tell u what is wrong(maybe)
3. it is NOT timing, our engines are what are called interference engines, which means if it is out of time, the cylinders will collide with the valves, causing them to bend, locking up the head, stalling the engine
4. the reason u have oil leaking down the engine is that u need to change ur valve cover gasket
Old Mar 31, 2008
wikkaco0's Avatar
wikkaco0 is an unknown quantity at this point
When you revv it up. What do you mean by it starting to want to die? Does the engine straight cut out, misfires, etc?
Old Apr 1, 2008
no when i first put it back together i took it down the street and on my way back i punched it and everything died on me. i could here the ecu cutting out befor it died. so i took the valve cover off to check and the sensor next to the came gear was off and the nut the held it on was stuck in the tensioner spring. whats cel? and how can i check it? also do i need to do a valve job? and is my car ok to drive? the valve cover gasket is a new, it looks like its comming from under the head. and i think i striped out one of the valve cover bolts.
if its not the timing then whats making it idle so high?
Old Apr 1, 2008
pheaton's Avatar
Well a bad sensor will do that. Do you have all of your bolts torqued to spec.?
CEL = Check Engine Light
If it were the timing your car would be running like a POS from the moment you started it, not just when you step on it.
Old Apr 1, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Those last questions you just asked kinda scared me....you shouldn't be messing with the timing belt if you have that many questions...
Research,Research, Research, & then fix!
You need to make sure all sensors are plugged in, set engine to tdc & check all timing marks, UNhook battery & reset check engine light (after sensors are checked), & perform valve adjustment..........
Old Apr 1, 2008
bomerman19's Avatar
Bingo you found your problem! that is the TDC sensor if it comes unbolted your car will run like **** you probably had it on close enough that when you started to drive it you did not have a problem but when you stepped on the bolt finally came all the way and your sensor slipped and stopped reading as for noise that bolt that came off and landed on the tensioner spring was probably bouncing around and making the majority of your noise
Old Apr 1, 2008
i fixed the sensor bolt befor i made the vids. so it cant be still bouncing around. wehn i had the top camgear cover off to fix it was sitting at tdc, as for the bottom i cant get it off. i had put a lighter one on and the stock one i used that damn tool. so i have to find some wrench with a chain thing on it
Old Apr 1, 2008
FoSho's Avatar
If you can't get your crank pulley off then how did you do the t-belt?
Also it sounds like you're not sure if the crank was at tdc?
wow...........tow it to a mechanic
Old Apr 1, 2008
no i am almost 100% sure that bolth where at tdc befor i put the aftermarket crank on after the put the belts on.
Old Apr 2, 2008
ok i just got it checked out, would this be the reason i idel wierd?
tps/pedal position sensor a:
IAT sensor 1:
Old Apr 2, 2008
yea, thats the throttle position sensor will make it idle funny, iat is what tells the car where to idle when warm and cold, and will make it idle funny too, u dont have an IAT resistor from ebay do u?
Old Apr 3, 2008
im not sure what you are asking bud?
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
DC5@EM2
Bolt-on Engine Performance
Dec 4, 2001 07:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
