HVAC system out of control
Old Jun 26, 2016
Taz1001's Avatar
Taz1001 is an unknown quantity at this point
Hello
I driver a 2005 Honda civic DX manual. Yesterday I was soldiering a usb cable to the power of the cigarette lighter. After I started my car the blower went on full (even when off) and none of the buttons/settings on my temperature control are working (AC, rear defog, recirculate, temperature, blower setting or the air vent setting). I went to the junk yard today assuming the controller units were bad so I replaced them but the issue persists. Also it randomly goes away( everything normal) for 2-3 minutes then back to blower on full and nothing working. I have searched the internet for hours with no luck, if anyone has an idea of what it might be please do share or a wiring diagram for the HVAC system would be great as well.
Thanks
Old Jun 27, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: HVAC system out of control
I would have checked the fuses first.
Old Jun 28, 2016
Taz1001's Avatar
I have checked all the fuses, The resistor/transistor and the relay. all are fine but the problem still continues
Old Jun 29, 2016
NDNV's Avatar
If you have checked all the fuses (there is likely more than one in this circuit)and the relay, you may have to undo your solder job. New head unit with a USB port instead?
Old Jun 29, 2016
CraigW's Avatar
Did you have the HVAC panel out to do the initial work ??
Old Jun 29, 2016
Taz1001's Avatar
No I was only working with the 2 cigarette lighter/plug wires
Xavier11
Jan 22, 2016 03:50 PM
paul.f
Nov 6, 2015 10:41 AM
trv020
Oct 28, 2015 10:37 PM
Civility
Oct 25, 2015 07:13 PM
