Transmission help!!!
Old Jun 18, 2016
Phillip Plypots's Avatar
Phillip Plypots is an unknown quantity at this point
I've taken my Transmission apart to replace a bad input shaft bearing in my 2005 Civic LX Special Edition (manual Transmission) Unfortunately, when I was lifting out the mainshaft and counter shaft assembly, the two washers directly next to the inputshaft bearing fell on the floor. Although the two washers look the same, they're different, on appears to be beveled and the other looks like a regular washer. I need to know what order those washers go back on the mainshaft so I can put the trans back together.
The 2 washers are shown in the video below at 6:00
Old Jun 18, 2016
Re: Transmission help!!!
How accurate is this picture for a 2005 Civic LX manual? Is this the correct order and direction for the two washers?
Old Jun 18, 2016
See if you can find the same thing in an online Honda parts catalog, for your car.
I can't tell if the SI reference in your pic is for USA (2.0L) or Canada (1.7L) or something else.
I think the orientation of the washers you circled are the same though.
Old Jul 16, 2017
StockDC2's Avatar
StockDC2 is an unknown quantity at this point
Old post but have the same issue. Does the straight washer go on top of the beveled one?
Emosteevo
Mar 24, 2017 03:51 AM
bgtg
Electrical
Nov 4, 2015 06:14 PM
danfry21
Oct 31, 2015 02:26 PM
ernie22lord
Oct 26, 2015 12:01 PM
elit3x
Oct 22, 2015 07:13 PM
