2005 civic rear turn signal issue
Old Nov 1, 2015
bgtg's Avatar
bgtg is an unknown quantity at this point
I have a 2005 civic and rear turn signal works sometimes and doesnt others...the bulb is fine and the tail lite part works but signal works and then doesnt (and it flashes wildly on the dash when it does this) what do i need to do to fix this issue...any help would be appreciated... thanks
Old Nov 1, 2015
Re: 2005 civic rear turn signal issue
You need to track down why this part isn't working:
Bulb or socket problem? Swap parts from the other side as a test, see if the problem moves
Old Nov 3, 2015
bgtg's Avatar
i played with the wires and it works sometimes when i move the wires around...is it the ground...is the black one going into the socket the ground wire...should i splice the black ground wire and ground in the trunk and see if that fixes the issue?
Old Nov 3, 2015
Wiggle that wire very carefully so you can narrow down to the exact point where it makes and breaks contact, then take that apart to see why?
Yes black is shown as the ground for the light. Grounds are bolted to the rear panel of the trunk area near the trunklid striker (remove plastic trims to see).
HTH
Old Nov 4, 2015
bgtg's Avatar
think i got it fixed now...thanks for the help.... TG
JohnnyBxo
Nov 12, 2015 03:04 PM
Anticrosswalk
Jul 21, 2015 01:37 PM
dbagaus
Jun 10, 2015 09:29 AM
AC
Dec 17, 2001 05:58 PM
civicPesek
Nov 7, 2001 11:33 PM
