Anyone know where this bracket goes?
Old May 30, 2016
stevedap's Avatar
stevedap is an unknown quantity at this point
This is pretty embarrassing. This small bracket was left over after I re-assembled everything after pulling the alternator, power steering pump, ignition wiring, front
timing covers"><span style=timing covers" /> timing covers">timing covers
, air intake and valve cover. It looks like a small bracket for an electrical connector or something but I don't see any place for it. I checked all the fiche diagrams at HondaParts but no luck in seeing it. It's got to be something that goes somewhere in the top front of the engine bay. Click image for larger version
Old May 30, 2016
Re: Anyone know where this bracket goes?
What car do you have? Year? # of doors? Hatch? Trim? Engine? Trans?
Old May 30, 2016
mac25's Avatar
Dr Krieger of Modification
The square top makes me think of the power steering res. bracket.
...but that's just a shot i the dark.
Old May 30, 2016
stevedap's Avatar
It's a LX 4 door, MT. Nice guess, but its not the P.S res bracket. Spent hours looking at parts diagrams for the stupid little thing.
Old May 30, 2016
Colin42's Avatar
Well, what's loose in the engine bay that shouldn't be loose? Either something electrical or a bracket for some tubing, like a clutch line. Those are my guesses.
Old May 30, 2016
Swing, and a miss.
Old May 30, 2016
stevedap's Avatar
Checked and double-checked... nothing loose or missing that I could see. Obviously it goes somewhere and I'm just not seeing it. Didn't touch the clutch line or starter motor. Pulled everything off to remove the valve cover. Did that. pulled the, air intake, thermostat, p.s pump, alternator and upper timing belt cover. That's it. Then put it back together and left with this one small bracket and M5 x 10 Phillips hex screw with lock washer. Yeah, I know it's supposed to go somewhere...
Old May 30, 2016
No idea what year the car is yet?
Old May 30, 2016
stevedap's Avatar
ahhh sorry... 2002
Old May 30, 2016
Would the bolt be 6mmx12?
No idea what it is, but it sure looks like it should be holding a wire harness up somewhere.
Couple guesses.....
bracket #10
bracket #14
bracket #11
Meh... I don't have a similar car to look at either
Old May 30, 2016
stevedap's Avatar
Couple guesses.....
bracket #10
bracket #14
bracket #11
Found it! It's a bracket that screws into the starter motor or "stay" as they call it to hold the wiring in place. #26 on the diagram. That bracket costs $47.70!!
http://www.hondapartsnow.com/genuine...1-PLR-A01.html
TS2008
Apr 13, 2016 06:27 PM
j.squared
Dec 17, 2013 06:47 PM
semvhu
Dec 1, 2013 08:38 PM
PCate
May 14, 2006 02:12 AM
AggressiveAdam
May 30, 2005 01:20 PM
