how to get evap monitor ready?
Old Oct 1, 2015
senicalj4579's Avatar
senicalj4579 is an unknown quantity at this point
I replaced the vapor canister vent solenoid and reset pcm. How long should it take for the monitor to be ready? This car needs to go through emissions but I need to know if the problem is solved. Thank you.
Old Oct 1, 2015
Re: how to get evap monitor ready?
If you don't have a reader you can plug in, try this:
Turn the ignition key to run but do not start the engine.
Watch the check engine light.
After maybe 15 seconds....If it starts flashing, the monitors have not completed and your car is not ready for testing.
If the CEL comes on then after several seconds it goes out and stays out, the monitors have completed....... and as long as your CEL is not on while the engine is running it's ready to test.
This should be in your owners manual if you still have it.
HTH
Old Oct 2, 2015
Thank you sir. The car did exactly what you described of being not ready. That was last night after driving it some.
This morning I did a cold start and drove 5-10 miles. The reader came back with everything ok. Went through the nanny emissions and passed. Good to go. Thank you.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
Bruce2
Sep 21, 2015 08:01 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
