Low compression
Old Sep 21, 2015
rezsst's Avatar
rezsst is an unknown quantity at this point
Low compression
Delete this if you want. Got a buddy with a 92 cx 1.5 d15b8. #1 50,#2-100 #3-75,#4-100psi. Obviously needs rebuilt. But could there be something else. Maybe timing belt.
Old Sep 21, 2015
mikey1's Avatar
Re: Low compression
low compression can be caused by many different things, i cant tell from here,
- blown head gasket
- damaged valves
- valves not sealing/seating correctly
- burnt valves
- incorrect timing
- extremely worn piston rings (unlikely)
- cam not turning at all (broken timing belt)
- loose spark plugs
Old Sep 21, 2015
Re: Low compression
Cylinder leakdown testing should be the next step.
Old Sep 21, 2015
rezsst's Avatar
Re: Low compression
Less than 150,000 miles #3 plug has alot of burnt oil on it.
Old Sep 21, 2015
Mad Dog Tannen's Avatar
Re: Low compression
May be a bad valve or bad rings, do the leak down test.
Old Sep 21, 2015
rezsst's Avatar
Re: Low compression
Thanks
Old Sep 26, 2015
92hatchbackcx's Avatar
92hatchbackcx is an unknown quantity at this point
Re: Low compression
Hello, I'm the friend with the low compression. I am not familiar with the leak down process, how do you do this?
Old Sep 26, 2015
Re: Low compression
Welcome.
Googled:
https://mobiloil.com/en/article/car-...-leakdown-test
http://www.gregsengine.com/cylinder-...n-testing.html
http://www.hotrod.com/how-to/engine/...akdown-tester/
It's basically pressurizing each cylinder with air so you can figure out where the compression loss (cylinder leakage) is.
Old Sep 26, 2015
Re: Low compression
Welcome.
Googled:
Thanks for the help, it's much appreciated!
Old Sep 26, 2015
Re: Low compression
I'd sure expect stuck oil rings at the very least.
If the head gets pulled, that would be the ideal time to take care of the rings.
SimpleUser
Apr 24, 2021 02:54 AM
CraigW
Aug 18, 2015 07:06 AM
jessica19699
Jul 30, 2015 01:02 PM
alxz310
Jul 30, 2015 12:18 PM
DerbyDad03
Jul 27, 2015 11:34 AM
