Help identify part in head gasket set
Old Jul 25, 2015
7thgensurvivor's Avatar
7thgensurvivor is an unknown quantity at this point
Mystery for you all. I bought a Fel-pro head gasket set for my 7th gen and it came with something I don't recognize.
See the attached picture and look at the metal flange / ring in the red circle.
Anyone know what that is, or where it goes?
Thanks in advance!!!
Name:	fel-pro head gasket set.jpg
Old Jul 25, 2015
Re: Help identify part in head gasket set
Just noticed, there is a piece missing in the kit pictured. My kit came with a copper flange / donut that I am pretty certain goes from my exhaust manifold to my exhaust. That copper flange does not appear to be pictured in the attached picture. The piece I have circled, is similar in shape, but slightly smaller, and polished metal, not copper.
Old Jul 25, 2015
mikey1's Avatar
hard to tell from that picture, but some type of exhaust gasket would be my 2 cent guess
Old Jul 25, 2015
Red circle looks like an O ring??.....
Could be for the water pipe across the back of the block or maybe a distributor if it had one.
I would not go looking for where it goes though.
If you take apart something and need it, there ya go.
If you don't take apart anything that needs it, then it's an extra.
Is it listed on the back of the box? Boxed kits can cover more than JUST your car/engine combo.
Old Jul 25, 2015
Thanks guys. Its not listed on the packaging. I think it has something to do with the exhaust further down than I am headed. I will take your advice and not worry about it.
Old Jul 26, 2015
i have parts left over from mine kit too.
Old Jul 26, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
part 21 maybe? I know I had to pry the pipe out of the back of the water pump when I did mine. I removed the head with the water pump still on it when I did mine. the gasket kit I ordered had an o-ring to replace the one on the end of the pipe.
Old Jul 26, 2015
Thanks drhawkinz, but that's not it. I had similar trouble getting that pipe out of there as well.
I've attached a higher res image of the part, but not going to worry about it for now. Will still give kudos if someone knows what it is though
Old Jul 26, 2015
mikey1's Avatar
i still say exhaust,
but not quite sure where
Old Jul 26, 2015
Good pic sure helps.
Exhaust donut.
It's the gasket for a spring-loaded exhaust joint.
Old Jul 27, 2015
drhawkinz's Avatar
I think that goes between the exhaust manifold and cat converter. interesting that it came with the head gasket kit.
HondaHomer
May 14, 2015 12:24 PM
hokiedad4
May 3, 2015 10:06 PM
hokiedad4
Apr 30, 2015 07:18 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
green01civic
Apr 29, 2015 01:36 PM
