Setting Threads
Old Jul 12, 2015
manfredww1's Avatar
manfredww1 is an unknown quantity at this point
Setting Threads
I screwed (no pun intended) up the threads inside the hole for the bolt for a front engine motor mount.
How do I fix this and if I take it somewhere what do you suspect it will cost me? Thanks.
Old Jul 12, 2015
GolNat's Avatar
Prelude Owner
Re: Setting Threads
I would re tap it.
There also thinks called Helicoils for fixing threads. I have never used one personally.
Old Jul 12, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Re: Setting Threads
You have to run a bottom tap through it and re-cut the threads. A heli-coil may not be necessary. You'd have to tap it before installing a heli-coil anyway.
Do a part lookup on the motor mount bolt, as if you were going to order one. It will tell you the thread size. Get the same size tap from harbor freight, northern tool, or whatever store you want.
Run the tap through slowly. As you run the tap through, when it feels tight, reverse direction a turn or so. Its cutting the threads, so when it gets tight, back up, don't keep going or you may break the tap. Then you'll have a tap to remove before you try it again.
See if you can find some videos on youtube to watch about tapping.
Old Jul 12, 2015
GolNat's Avatar
Prelude Owner
Re: Setting Threads
Use an oil while running the tap!
Sep 26, 2023 06:44 PM
GolNat
Jan 12, 2021 09:06 PM
manfredww1
Jul 14, 2015 10:24 AM
Jul 12, 2015 11:54 AM
MamaBear2015
Jul 3, 2015 11:26 PM
