Something went wrong when put in new actuator... help!
Old Jun 28, 2015
h4ldol's Avatar
h4ldol is an unknown quantity at this point
I just finished changing my driver's side actuator to see if that would solve my power lock problems (power lock switch on driver's side, nor the key fob, does not unlock/lock driver's side lock, but does unlock/lock the passenger side; key turns lock fine). So, it was a big pain because I couldn't get one of the wires/cables to unhook from the door lock assembly, but I seemed to get it done in the end but when I put it all together again I found that it still doesn't work, but now the key doesn't physically turn the lock. I know I reconnected the wire that goes to the inside door handle so I guess I must have forgotten to unhook one of the cables/wires that goes to the lock assembly in the door? Or could it be the actuator was installed incorrectly?
Old Jun 28, 2015
h4ldol's Avatar
Re: Something went wrong when put in new actuator... help!
So, actually it turned out to be simple: I just forgot to reattach one of the rods that connects to the door lock/handle assembly. And I also forgot to attach the electrical connections to the new actuator, lol. So after doing those two things my power door locks work fine again. The only issue, which is minor for now, is that when I use my key to manually lock/unlock the door, it doesn't feel as "smooth" as it did before I changed the actuator. Probably I'm guessing it's due to some of the rods getting bent during the process as I couldn't remove one rod and so I switched the actuator without actually removing the lock assembly so there was some bending involved probably. For now, though, I'm not going to worry about it.
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
sbi
20
Oct 23, 2015 01:34 PM
01civyv3
Jun 2, 2015 05:21 AM
usajags84
May 30, 2015 06:49 PM
Pudnite
May 9, 2015 07:51 PM
