low idle miss
Old Jun 8, 2015
Vanman's Avatar
Vanman is an unknown quantity at this point
low idle miss
I have an 03 LX. 181,000 miles. New timing belt and new fuel pump along with new spark plugs installed. I have a terrible miss while idling. No specific codes pop up, it just says I have a miss on each cylinder. My engine light flashes at idle and low speeds. At higher speeds it just stays on.
Please help.
Thanks,
Vanman
Old Jun 8, 2015
Re: low idle miss
Did this problem start immediately after the
New timing belt
was installed?
Old Jun 9, 2015
Vanman's Avatar
Re: low idle miss
No, I replaced the belt and had no problems for quite some time.
Old Jun 9, 2015
Vanman's Avatar
Re: low idle miss
If anyone has any thoughts, ideas, I'm open to suggestions.
Old Jun 9, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: low idle miss
My car had a similar issue and I did a compression test on it and found that I had a leaky valve. So I'd start with a compression test and see what you find.
I would suspect that your timing is maybe off a tooth.
Old Jun 9, 2015
Re: low idle miss
Got an actual fault code(s)? What is it?
Erase the codes, then run it long enough to flash the engine light again, then immediately recheck to see what code(s) it set.
What's the code now?
If you can figure out which cylinder is the dead hole, you can concentrate on it instead of checking all 4 (for some things).
freyes23
Jun 21, 2015 10:37 AM
Ninetyatecivic
May 9, 2015 07:48 PM
jakeconnor
May 5, 2015 07:30 AM
usajags84
Apr 10, 2015 09:54 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
