Strut bolt keeps working loose
Re: Strut bolt keeps working loose
Was the nut reused?
Was it supposed to have been replaced?
Some are only supposed to be one time use.
I have taken my front struts off many times and always re use the same bolts. Never had an issue with it not staying tight.
You could use a lock nut but you shouldn't have to, it should stay tight without one.
Hex key in the center?
Which bolt is it? The crash bolts that attach to the knuckle or the ones on the strut mount? The only one that usually has a hex key in the center is the strut rod which does not get turned. That hex key is used to hold the rod steady while you tighten the nut.
ORskier
May 3, 2015 12:54 PM
GH04si
Apr 15, 2015 08:13 PM
