2005 honda civic
Old Dec 7, 2014
ikennaumehc's Avatar
ikennaumehc is an unknown quantity at this point
2005 honda civic
i noticed my 2005 honda civic belt,cuts all the time.what may actually be the fault.is it that the power steering pump is bad?
Old Dec 7, 2014
Re: 2005 honda civic
Old Dec 7, 2014
I underlined the part that seems to make no sense to me.
Please try again.
Old Dec 7, 2014
Please try again.
what i meant,was that i keep replacing the belt on my power steering pump.cause it keeps cutting or pulling out.and each time it happens my battery light comes up and my car starts over heating.what is actually the problem and solution to this?my 2005 honda civic
Old Dec 7, 2014
Explain more? Your descriptive terms aren't meaning anything to me yet, I can't picture what you are seeing.
Maybe you mean you have been replacing the alternator belt? And it keeps coming loose?
Is the alternator not correctly bolted on, bolts not properly tightened?
Do you only notice this on the gauge, or does it spew antifreeze out?
Do the radiator fans operate correctly?
Blown head gasket?
Old Dec 7, 2014
Brandon@fattysmotorsports's Avatar
Former Sponsor
Brandon@fattysmotorsports is an unknown quantity at this point
So your belt keeps coming off, or cutting off? belt installed correctly?
Old Dec 8, 2014
i think the problem should be from the quality of the belt.cause under a space of 2yrs i have changed the belt 3 times.actually my mechanic said my power steering pump is bad.dont know if that can make the belt cut.
Old Dec 8, 2014
the alternator is properly fixed.i feel while the car is on motion the belt keeps wearing off till it becomes weak and sometimes it pulls out or cut.
Old Dec 8, 2014
Blown head gasket?
the over heating and the battery light comes up when the belt pulls out or cuts.it makes the car move slowly and it kills the battery life.cause the belt that rolls the alternator is out.
Old Dec 8, 2014
So...What does your mechanic say about the belt problem now?
Old Dec 22, 2014
not an 8th gen - moved
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
twtron
Apr 17, 2015 12:09 AM
gabrown2
Apr 11, 2015 08:22 PM
