erratic tach and speedo
Old Sep 24, 2014
seriba31's Avatar
seriba31 is an unknown quantity at this point
Hi, i'm having trouble finding cause of erratic tach and speedo.
They are erratic because they sometimes work and sometimes don't.
the tach, when erratic, either just shakes or starts at wrong position. when it starts at wrong position, movement seems to be normal though. Usually, it can be reset to zero by turning key on/off several times untill needle goes back to zero. Each key on/off turns back needle by a few notch.
same description happens to speedo.
any help pls? thanks.
Old Sep 24, 2014
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: erratic tach and speedo
I'm assuming you have a 7th gen civic.
1. push/hold the trip button.
2. turn the headlight switch on completely.
3. turn the ignition switch on to accessories (II).
4. (within 5 seconds) turn the headlight switch OFF, then ON, and OFF again.
5. (within 5 seconds) release the trip button
6. push and release the trip button 4 times repeatedly.
this starts the gauge cluster self diagnostics...
the beeper will sound
the lights will flash
the LCD will flash
the needles will sweep
if they/one does not sweep properly, replace the cluster.
Old Sep 24, 2014
have you tried doing instrument cluster test to check how all the needles work?
Old Sep 24, 2014
seriba31's Avatar
i tried gage cluster sweep test many times.
i got differing results.
- sweeps normal and returns to zero
- sweeps normal but returns to a position that is not zero
- shakes at end of right sweep then don't return
Old Sep 24, 2014
I think this covers it.
Old Sep 24, 2014
A speedo shop may be able to repair yours if you aren't inclined to buy another cluster.
Old Sep 24, 2014
seriba31's Avatar
Thanks, I'll check if some used ones are available
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bruce2
Sep 21, 2015 08:01 PM
MamaBear2015
Sep 15, 2015 09:35 PM
Bricoleur
Sep 9, 2015 12:23 PM
KikAzz
Sep 4, 2015 12:36 PM
