Surging Throttle
Old Aug 26, 2014
rmcgee73's Avatar
rmcgee73 is an unknown quantity at this point
Surging Throttle
I've been trying to replace my downstream o2 sensor. Started with the universal and still had the CEL and code. I just put a new Bosch OEM and CEL came back on. Code reads P0134 ckt no activity. I have another o2 sensor ordered in. Since the whole O2 sensor ordeal I've noticed the engine surges while accelerating going down the road. Does it sound like the O2 sensor would cause the surging, does the code mean I'm not getting enough voltage to the O2 sensor heater, or try cleaning the TPS? Go figure this is all happening when I'm ready to sell it. I had the head gasket, timing belt, water pump, plugs/wires at 120K miles when the head gasket blew.
Old Aug 26, 2014
rmcgee73's Avatar
Re: Surging Throttle
Sorry, this is on a 2004 EX 4 door, 1.7L, automatic
Old Aug 26, 2014
Throw away all of the Bosch parts.
Install the correct DENSO or NTK sensor(s), whichever brand was installed at the factory.
Old Aug 27, 2014
rmcgee73's Avatar
So, you think the O2 sensor is the cause of my surging? It doesn't do it all the time either.
Old Aug 27, 2014
The problem started when you changed it? Absolutely!
Hear me now, believe me later!
The car was not built with Bosch parts.
You need to use the sensors the factory designed the car with.
You need to use the correct A/F sensor. (It is not an oxygen sensor.)
Search here for codes P0134 and P0135 on 04-05 civics.
https://www.civicforums.com/forums/266-basic-engine-performance/360074-02-sensor-check-engine-light-issue.html
https://www.civicforums.com/forums/36-mechanical-problems-vehicle-issues-fix-forum/344101-04-civic-ex-cel-p0135-p0134.html
Bruce2
Sep 27, 2015 08:45 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
NROD315
Sep 23, 2015 03:46 PM
Bricoleur
Sep 9, 2015 12:30 PM
thaler4cuse
Sep 7, 2015 08:25 PM
