Hot headlight
Old May 10, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
Hot headlight
i putted my hand in the front headlights and realized they are very very hot...i am using Showoff Krypton 4300K bulbs
is it very bad for the entire headlight unit? would it melt something???
Old May 11, 2002
Macko's Avatar
Macko is an unknown quantity at this point
They only way i'd alter my lights is get a real HID kit, which has the diffusor... those xenon bulbs and the ones that mimic HID use more power to get brighter light and heat up more.... although there are some bulbs which are certifed and DOT approved for brighter light...
Just my 2 cents
Old May 11, 2002
iamfob's Avatar
so should i still using those hyper white bulbs or switch back to the oem bulbs?
Old May 11, 2002
2cute's Avatar
2cute is an unknown quantity at this point
They are heating up because of the lights you have in there I'm suprised part of the headlight hasn't started to burn as well. If you want that to go away replace the OEM bulbs.
Old May 12, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Well I have the Xtreme PIAA in there the low end one not the high watts ones and never had a issue. Its been 10,000 miles with those now.
Nick
Old May 13, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
i think some people have had their headlight housings melt from the higher wattage bulbs, if they are getting hot, you might want to switch back to lower wattage bulbs
Old May 13, 2002
2cute's Avatar
<< i think some people have had their headlight housings melt from the higher wattage bulbs, if they are getting hot, you might want to switch back to lower wattage bulbs >>
Did I not say that already in almost the exact same words?
<< They are heating up because of the lights you have in there I'm suprised part of the headlight hasn't started to burn as well. If you want that to go away replace the OEM bulbs. >>
I think those sound VERY familiar
Old May 13, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
yeah that's bad mojo for the civic.
shaejb15
Sep 12, 2015 01:02 AM
Ultra Havoc
Sep 9, 2015 10:58 PM
Bricoleur
Sep 9, 2015 12:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
