02 oem plug
Old Jun 17, 2014
Ocoee's Avatar
Ocoee is an unknown quantity at this point
02 oem plug
What is the oem or recommended plug for an 02? If not an ngk zfr6fgp, what do you think of the ngk zfr6fgp?
Old Jun 17, 2014
GolNat's Avatar
Prelude Owner
Re: 02 oem plug
Either an NGK or Denso. Should be Iridium.
Those are the best plugs, period.
Old Jun 17, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Re: 02 oem plug
I like the Denso OEM-spec plats. Not sure what the iridium spec would be for a Denso equivalent, but these OEM-spec plats haven't misses a beat since installation. The spec NGKs have given other 7th-gen owners including myself, much grief. I can see why one would want to avoid paying the left arm for four of the spec Densos, though...
Since the plat spec for the plugs are 100K, I don't personally see where a harder iridium plug would make much difference, personally. If they have some other advantage, I'd like to hear what it is... but it's not greater efficiency. The hardness is the only advantage over a plat equivalent with the same electrode design and heat range AFAIK.
Enigma346
Lighting
Jul 12, 2015 08:24 PM
CivicsClass101
Jul 9, 2015 11:14 AM
hayden55
Jul 8, 2015 11:38 PM
hatch90
Jul 5, 2015 01:17 AM
MamaBear2015
Jul 3, 2015 11:26 PM
