quick question, driver's side inside door handle...
Old May 27, 2014
churchie's Avatar
churchie is an unknown quantity at this point
... hi, please point me in the right direction, inside door handle is pulled out, won't open door but outside handle will. Clip and rod inside look fine.
Thanks, churchie
2002 Civic EX, going to turn 170k next week.
ID:	86680   Click image for larger version
ID:	86681   Click image for larger version
Old May 27, 2014
Re: quick question, driver's side inside door handle...
So even if you pull the inside rod forward by hand you still can't open the door with it?
I'd pull the door panel off and make sure the linkages (rod) are free, not caught in vapor barrier sticky goo...and is still mounted in the guide clip.
then maybe I'd vote for a bad latch.
Old May 27, 2014
churchie's Avatar
Just tried, if I pull the driver's side rod forward (towards windshield) I get nothing.
I tried it out on the passenger side for comparison - presto tugging the rod forward opens door no problem.
Thank you, I'll follow your other suggestions.
p.s. If there is a another useful post please send me the link. I tried the search engine before posting, but an exact phrase feature doesn't appear to be available.
Old May 27, 2014
Here's one for replacing the window regulator that covers getting the door panel off.
https://www.civicforums.com/forums/3...vic-coupe.html
Old May 27, 2014
Here's one that covers the latch and power lock actuator.
http://www.justanswer.com/honda/3ake...ivic-need.html
Use a hand impact driver to get the big phillips screws loose in the back edge of the door.
Old May 28, 2014
churchie's Avatar
Thank you Ezone.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Poopies
Apr 20, 2017 11:36 PM
pratik05
May 15, 2015 01:54 PM
MamaBear2015
May 3, 2015 02:17 PM
MooCoW
Nov 9, 2001 05:22 PM
