VTEC wont work
Old May 25, 2014
  #61
Prestond17's Avatar
Prestond17 is an unknown quantity at this point
Exclamation Re: VTEC wont work
Well I'm almost 100% sure they were connected to the right plugs......... BUT i did buy the sensor (from pull N pay) that plugs into the VTEC and cut my old one off and spliced the new one in because mine was damaged and it only had one wire in it and i figured it was supposed to have 2 wires since the one i got from Pull n pay has 2 wires, the one i put on has a blue wire and a black wire, why does it have a black wire? Ground?... That shouldn't be a problem right?
Also that thing that doesn't have anything plugged into it is exactly where it says knock sensor on that pic you just sent... So am i missing something? And if so what's that mean? Please let me no ASAP, I'm trying to fix as much as i can right now
Old May 25, 2014
  #62
Prestond17's Avatar
So your saying the oil light issue has nothing to do with the VTEC not working? If not I'll worry about that after i fix my VTEC. And yea i bought a honda book but i dont fully understand how to read wire diagrams... I guess i can figure that out on YouTube tho, why do you ask? I looked in it a little and i couldn't find anything to help with my problem.
Also i forgot i had someone tell me my car was in "LIMP MODE" do you no anything about that? Ever heard of it?
Old May 25, 2014
  #63
Prestond17's Avatar
Re: VTEC wont work
My oil pressure switch wire goes up to the left tho not to the right like in the picture, someone must have just put it on the wrong bracket at some point. Idk
Old May 25, 2014
  #64
Re: VTEC wont work
Did you pay money for the dealer to not see any of this?
The wire (engine harness) colors going to the switch should be brn/yel and blu/blk
Yep, it sounds like you must be missing something. A 3 wire connector. And you should have a knock sensor code if it is unplugged.
Can't say it for sure yet, not until one figures it all out.
I think the oil pressure light is not caused by low oil pressure, but rather caused by something else grounding the yellow/red wire. Now if someone plugged THAT wire into the gray connector on the VTEC, then that would make it a related problem.
You wanted to know how to get the cluster out.
Plus, it should have troubleshooting procedures so you can figure out your VTEC code problem.
That's the rev limiter after it sets the code for VTEC not working right.
So what's it connected to?
Old May 26, 2014
  #65
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: VTEC wont work
OP, take your oil cap off and shine a light inside your valve cover. Do you see any sludge build up? Any chunks of oil covering stuff inside the valve cover?
Old May 26, 2014
  #66
Prestond17's Avatar
Re: VTEC wont work
Ha no i didnt pay them to not say anything they just did a half *** job prolly cause they didnt think id be able to pay them right when really i would have paid just as easy as anyone else... But that just may have been a dumb tech like you said.
If allowed the wire (and i lied i thought it went left it does go right) and i didnt have time to get into the cluster but i didnt find any shorts or grounded spots so idk i am going to get the volt tester thing and oil pressure tester and go from there i guess
Old May 30, 2014
  #67
Prestond17's Avatar
Re: VTEC wont work
That last post was supposed to say i followed the wire, not "if allowed" ha sorry. And i will be working on it all tomorrow sorry i havent updated in a while. Ill post everything when i get into it asap
ORskier
May 3, 2015 12:54 PM
LionSpratt
Apr 26, 2015 01:02 PM
Tybonater
Apr 24, 2015 07:03 PM
SatinSilver2k1
Dec 12, 2001 06:32 PM
CivicPunker17
Dec 1, 2001 06:58 PM
