Fuel Door / Trunk Lever
Old May 3, 2014
mikey1's Avatar
about 3 weeks ago my fuel door would not open using the interior lever, since then i have been opening it manually from inside the trunk by removing the big black piece that screws into the frame, and then screwing it back in to lock the door again,
today i tried to open the trunk using the interior lever and it would not open, i then tried to open up the fuel door using the lever, and to my amazement the fuel door now works! its like the problem has reversed all by itself,
i havnt had a chance to dive into this and take anything apart yet, wondering if this has happened to anybody else or heard of this happening
Old May 3, 2014
CraigW's Avatar
Re: Fuel Door / Trunk Lever
01-05 ??
If so,the metal crimp they use on the cables corrodes and can cause problems.
Look into fueldoorfix. Trunk may be another story.
Old May 3, 2014
mikey1's Avatar
Originally Posted by CraigW
01-05 ??
yes its an 05,
i have heard about fuel door fix, but my fuel door is now working!
Old May 3, 2014
CraigW's Avatar
I popped an FDF in place on the 05 before my daughter got it. You may have to pull the panels and have a look. I would suggest and FDF to any 01-05 owner (the new cable crimps are now brass), it will go on even if your gas door still opens.
mohawkboom
67
Aug 25, 2015 12:28 AM
Jeffdp
Aug 5, 2015 11:38 AM
Nalmonte
Jun 3, 2015 11:01 AM
Youshoe
May 22, 2015 09:36 PM
werdnahall
May 17, 2015 11:37 AM
