AC Thermal Protector
Hi there I just picked up a 2004 Honda Civic GX and realized the ac was not working. The compressor is not engaging at all and so I went to test the thermal protector. However, upon checking I see 3 red wires instead of a red and blue w/ white stripe coming from the compressor. Am I looking at the right thing? If so how do know which wire is which?
Nevermind. Got it by jumping the relay and then trying the different wires to see which one would make it click
Re: AC Thermal Protector
One wire is for the compressor clutch (blu/red, the center wire)
The other two wires are for the thermal protector.
My current idea is that my multimeter should find continuity on the 2 thermal protector wires and not the compressor clutch. Can somebody confirm that this is a valid test? Obviously if the thermal protector was bad this would not work.
Good idea, except when they are all red a wiring diagram doesn't help.
With a good wiring diagram you can refer to the terminal positions in the connector instead of wire colors.
First attach one test lead to the compressor body (ground), and probe the other to each of the 3 wires. The wire to the field coil will be the only one with a reading to ground, probably 2-4 ohms. Should be the center wire in that connector as already stated.
The other two should have continuity only to each other, that's the thermal protector. The 2 outer wires in the connector.
I see your edit that you figured it out anyway.
HTH
chadds
Sep 9, 2015 05:26 AM
LSC
Jun 20, 2015 06:48 PM
dinsum
May 28, 2015 09:30 PM
