Transmission confusion
Old Mar 17, 2014
K_Jordan2323's Avatar
K_Jordan2323 is an unknown quantity at this point
Hey guys new to civic forums thought id ask to see if anyone has had any past experiences like i have with this problem.
problems:
No reverse (budges but wont move)
cant go above 20 ish mph in Drive or about 2000-3000 rpm
engine light.
Got codes read at autozone and they were
P1298 and P 0370
the receipt for the codes says definition-Electrical load detector and faulty shift control system.
any help would be much appriciated thank you.
Old Mar 17, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Re: Transmission confusion
I'd title this post 'automatic' transmission confusion, simply to aid searches for new posters in the future.
Sounds like a transmission shift solenoid failure -- but I'd let the vets here give you the experienced scoop.
Old Mar 17, 2014
problems:
engine light.
P1298 and P 0370
Year of car?
Model?
Body?
Trim?
Engine?
Mileage?
Your location?
Ignore P1298 for the moment, that can't cause a trans problem.
P0370 does not exist.
P0730 is "problem in shift control system"
No reverse, won't go over 20....I bet it needs a trans.
Old Mar 17, 2014
Originally Posted by ezone
Year of car?
Model?
Body?
Trim?
Engine?
Mileage?
Your location?
civic 2001 ex coupe 185k michigan
Old Mar 17, 2014
Year of car?
Model?
Body?
Trim?
Engine?
Mileage?
Your location?
a little side note is that if i drive in D3 i can reach speeds of around 50
Old Mar 17, 2014
An 01 with 185k on the original trans? You musta got a good one if it lasted that long.
(Meaning: It's probably time for another trans.)
What if you start with the shifter all the way back in 1st gear and manually upshift it through the gears?
Does the trans bind up in 1st?
At any point does it feel like it goes to neutral instead of engaging the next gear?
I found a bulletin for no movement in drive, code P0730, caused by worn 2nd gear clutch...
EDIT: Link: http://honda-tech.com/showthread.php?t=2193746
Old Mar 18, 2014
it is an automatic sorry for not specifing and the only time it feels as if it were in neutral is in reverse.
Old Mar 18, 2014
I realize it's an automatic..
You can manually shift an automatic trans, just pull the shifter all the way back, then bump it forward one notch for each next gear.
I was trying to figure out what was going on with being able to do 50 in D3 but only 20 in D.
Does it skip gears when driving in D? Erratic shifts? Flares between gears?
I'm trying to assess as many different symptoms as I can gather at once here.
The goal is to figure out if this is an internal trans problem or an electrical related problem outside of the trans.
But I think it's going to be internal, as in overhaul or replace.
Found this one in the troubleshooting charts:
Poor acceleration/ flares on starting off in D and D3/ stall speed high in R
Likely problem in 4th clutch
Next steps would involve checking fluid pressure for that clutch pack as part of a diagnosis.
HTH
Old Mar 19, 2014
HTH
In D it dosent seem to skip gears it just wont engage the rpms into mph past 20 mph in drive. Im going to run it into the local transmission shop and have them diagnose it
SidCivic
44
Oct 12, 2017 03:39 PM
xeroid
Aug 31, 2015 10:53 PM
knknif
Aug 4, 2015 06:11 PM
Smokahontas123
Jul 22, 2015 10:07 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
