Engine Degreaser caused Auto Tranny problem???
Old Mar 10, 2014
cjautomotive's Avatar
cjautomotive is an unknown quantity at this point
I used a can of Engine Degreaser, sprayed it all over the engine compartment. Let sit 15 minutes. Garden hose to rinse (thoroughly, I believe). Parked in sun to dry for a couple hours with hood open.
Drove about 25 miles on interstate. Engine Malfunction light came on as I lost power to wheels. Felt a slip of transmission just prior.
Engine running fine.
Side of road: oil and tranny fluid present via dipstick check. No visible leaks or items dangling under car.
Two hours later returned to car. Engine Malfunction light still on. Started easily. Transmission engaged smoothly (R 2,3,D).
Made it 50 yards. Same thing happened. Coasted to shoulder. Called tow.
I changed out the trans fluid a few days ago via the "drain and fill x3" technique.
My neighbor is thinking linkage, but I welcome your input. I am showing code P0730 which is the Improper Gear Ratio code. And I see a lot of info here about tranny problems showing that.
Dealership recently said I need new motor mounts all around incl. tranny mount. I have ordered them.
What should be my plan of attack?
Replace Mounts first?
What about transmission solenoids and harnesses? Maybe degreaser affected wiring?
2002 civic ex, automatic transmission, 130,000.
thanks!!
Old Mar 10, 2014
Re: Engine Degreaser caused Auto Tranny problem???
Anyone think the degreaser may have affected the solenoid?
Old Mar 13, 2014
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
It shouldn't. Did you try cleaning the electrical connectors on those solenoid?
What fluid did you use? Also, try doing a ECU relearn.
If that fails try to clean the shift solenoid screen. See attachment.
P0730 Honda - Faulty Shift Control System
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
File Type: pdf
Old Mar 17, 2014
Now THAT's a plan! Thanks for the doc
"If that fails try to clean the shift solenoid screen. See attachment."--does this refer to the "filter/gasket E" on 14-117 (2,4)?
I used Maxlife ATF. Don't know what previous owner had in there. Lots of shavings and metallic sludge on the plug magnet.
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
crowtoo
May 11, 2015 06:50 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Unstoppable
Nov 7, 2001 11:50 PM
