03 oil leak issues
Old Feb 28, 2014
dav3036's Avatar
dav3036 is an unknown quantity at this point
Question 03 oil leak issues
ID:	86412hello forum, i have a 03 sedan lx model, i recently changed the valve cover gasket but i'm still having oil pool underneath this area. is there a seal behind this area that could be causing the oil to pool? i've checked the gasket and it's sealed tight. no one at the particular parts stores around here can seem to find what part this calls for. any input would be greatly appreciated.
Old Feb 28, 2014
crxmanpat's Avatar
Pusher Jets Rule!
crxmanpat has a spectacular aura aboutcrxmanpat has a spectacular aura about
Re: 03 oil leak issues
You need to replace part #6 in this diagram (less than $10):
6 Part #12513-P72-003 PLUG, CYLINDER HEAD
This is where a distributor used to mount to before Honda started using the Ignition coils over the spark plugs. The o-ring in the plug wears out and is notorious for dripping oil.
Old Feb 28, 2014
^#6, gravy.
Old Mar 1, 2014
dav3036's Avatar
thanks a lot. going to get on top of it asap.
LionSpratt
Jan 29, 2017 11:07 PM
davidpaustin
May 20, 2015 12:59 PM
BootyDo
May 7, 2015 04:46 PM
silverdevil
Feb 6, 2002 03:29 PM
Grey
16
Jan 27, 2002 11:34 PM
