Couldn't figure out the connection in this pic
Old Feb 23, 2014
shibumi's Avatar
shibumi is an unknown quantity at this point
Hi guys,
I have civic 2002 HX coupe. I noticed this wire just came loose and could not figure out where should I attach it!
Here is the pic. It the black wire kept on the top of fuse box on the left.
Please help!
Thanks.
Old Feb 23, 2014
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Couldn't figure out the connection in this pic
It's really hard to tell from that pic. Would need to see the connector closer. Kind of looks like a shock sensor. Don't think it's a relay.
Looks like an after market connection for an alarm or stereo, but you would have to trace the wires back through the fire wall.
It's either power or ground. Or both since it looks like two loose connections.
Old Feb 24, 2014
I only see one wire. It's got a fuse holder so it was probably a hot (+) wire. Definitely for some accessory, probably something the previous owner installed, and then likely removed before selling the car.
Like TiggerDX said, stereo, alarm, remote start, something like that.
Ignore it or remove it. If you remove it, you can find out where it went and guess what might have been there.
Old Feb 24, 2014
TiggerDX's Avatar
It's hard to tell but it looks like there is one loose wire at the top of the fuse box and one at the bottom, just after the plastic holder.
I originally thought it was a fuse holder but it looks like there are two bolt holes to hold it down, so not really sure what it is.
Old Feb 24, 2014
Ok now I see it (bigger laptop at home now LOL).
A fuse holder on one wire with an eyelet (was probably bolted to a hot stud in the fusebox) and a (probably a) ground eyelet on a separate wire.
Fuse holder like this
Still ain't factory.
Old Feb 26, 2014
shibumi's Avatar
Guys, thank you for the information.
There are two fuse holders towards the end of the wire. I tried to trace the other end of the wire, it enters inside of the car on the right side. I am still searching where the end of the wire attaches.
Jeffdp
Aug 5, 2015 11:38 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
McLean
Jun 13, 2015 10:32 AM
rcolosi
Apr 29, 2015 07:48 PM
ImmortalEX
Nov 8, 2001 09:52 PM
