alternator mounting bracket
Old Nov 15, 2013
maver1k's Avatar
maver1k is an unknown quantity at this point
First off I apologize if this topic is on the forum somewhere else but I searched and diddent find anything related. So if I am a D.A. and it is here somewhere please direct me to it. thx
ok I have an 02 civic ex and my alternator needed replacing. ok no biggie fairly easy job spray everything down with liquid wren hand get started. as I was taking off the main mounting bolt( not the tensioner) to the alternator it snapped flush with the mounting bracket. so my desperate question is this.is that "bracket" a bracket or is it cast into the block? it looks as there is bolts holding it in place but I am not shure. I need to find a way to either get that bolt out or drill it out and use it as a threw hole but there is hardly enuf room to get a drill in there as it is.
any help is greatly appreciated thank you so much.
Old Nov 15, 2013
Re: alternator mounting bracket
The bolt you reach from above (the real long one), is threaded into a separate bracket attached to the block with 5 bolts. (Timing covers should come off to get the bracket off.)
#1 in this pic
Linky:
http://www.hondaautomotiveparts.com/...UNTING+BRACKET
You may be able to get the bracket off and drill out the broken bolt, then install a heli-coil? (That bracket is way cheaper than my time would be valued at to drill it.)
GritzNGravy
Aug 19, 2015 03:03 AM
DerbyDad03
Jul 27, 2015 11:34 AM
jzhartman
22
Jul 23, 2015 10:42 PM
671civicLX
Jul 9, 2015 03:22 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
