HELP: weird vibration at cruising speeds
Old Oct 22, 2013
CPV35's Avatar
CPV35 is an unknown quantity at this point
Hi everyone,
I am new here, just recently bought a used 2003 Honda Civic Coupe for the winter months.
The car runs great except for the fact that when I am cruising going around 60km/hr(40MPH) at around 1500-2000rpm there would be a loud vibration noise which causes the steering wheel to vibrate. Also, the rpm meter jumps up and down a bit at that rpm range. The vibration would go away when i let go of the throttle or step hard on the throttle to pass 2000rpm. The previous owner said the car needs alignment, so I did but the vibration is still there.
Any help would be appreciated! Thank you
Old Oct 23, 2013
GolNat's Avatar
Prelude Owner
Re: HELP: weird vibration at cruising speeds
The suspension should be evaluated for any worn parts, also your tires checked to make sure they are balanced. Easy way to check the tires is to swap the front and back tires. Motor mount could also have worn and should be checked.
Old Oct 23, 2013
Got misfire codes yet?
Got ANY codes yet?
Old Oct 23, 2013
CPV35's Avatar
Okay i will look into the suspension parts. Ty
alaga
25
Aug 13, 2015 04:42 PM
jpandjf
Aug 3, 2015 05:02 PM
BootyDo
Jul 26, 2015 10:38 AM
Jul 12, 2015 11:54 AM
1khilari
Jul 9, 2015 08:12 PM
