Charging iphone 5 on civic '03 si
Old Sep 18, 2013
tallgeese's Avatar
tallgeese is an unknown quantity at this point
Hey, was wondering how can I charge my iphone on a 03 civic. I plug the charger in a usb car adapter, but it doesn't work. Thanks, sorry if its a dumb question.
Old Sep 18, 2013
GolNat's Avatar
Prelude Owner
Re: Charging iphone 5 on civic '03 si
Did you turn the key to the acc position (II)?
Fuse could be blown, check fuse box under steering column.
If you want it to work without the key in the ignition and turned to acc your going to have to wire in a toggle switch to turn it on and off.
Old Sep 20, 2013
tallgeese's Avatar
I tried that, but that didn't work. But there should be no problem for the car to charge an iphone 5?
Old Sep 20, 2013
GolNat's Avatar
Prelude Owner
No it should charge the phone just fine.
You must have a blown fuse. Check the fuse box.
If that's good then get another cable or USB charger to see if that works, maybe your cable or charger is bad.
Old Sep 20, 2013
tallgeese's Avatar
Thanks. I thought it'd be okay because the USB adapter lights up, but I'll check it out. Thanks.
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
alexkharden
Apr 23, 2015 07:13 PM
SSMatey
Apr 13, 2015 06:09 PM
