central locking problem
Old Jul 24, 2013
mattym83's Avatar
mattym83 is an unknown quantity at this point
Hi all my central locking has started playing up. First the rear drivers side lock would occasionally would not work then it became more regular. Then it the passenger side rear door start playing up. Eventually the locks stopped working all together. Then it became the same issue on the passenger door and now the drivers door is playing up.
Is the mechanism that does the locking need replacing or are they just requiring a bit of lubrication as the issue is now affecting the drivers door it is very frustrating. I am hoping there is a simple solution to this
Thanks
Old Jul 24, 2013
GolNat's Avatar
Prelude Owner
Re: central locking problem
Need to remove the door panels and test the switch to see if that is working properly. If the switch is working then you to check for lose connections in the wires. I doubt all the locks went bad at the same time but they could be getting lazy and slow.
Old Jul 24, 2013
CraigW's Avatar
01-05 ??
Old Jul 24, 2013
mattym83's Avatar
Hi its an 01 civic
Switch seems to be working certainly makes the noise to say so and the drivers door is only occasionally playing up at this stage
Old Jul 25, 2013
CraigW's Avatar
If you have keyless (EX) watch the lock **** on drivers door when you single press remote for the very 1st time after setting overnight. It should move quickly up, if it is slow/sluggish it is a sign of failing actuator.
civic1316
May 29, 2015 05:13 PM
Youshoe
May 22, 2015 09:36 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
