p0301, 302, 303, 304 but only when at operating temp? please help!!
Old Jun 3, 2013
smajr85's Avatar
smajr85 is an unknown quantity at this point
Ok, i am getting all for misfire codes. Car was brought to me after a local shop replaced head gasket. Runs great when cold, but when at operating temp not so much. If you keep the car above 2500 rpm, it runs like a scalded dog, but if you let the rpm drop i will stall when you hit the accelerator. The tps is reading correctly, i have 45psi fuel pressure, map is around 16inhg at idle. IAT seems normal. My qestions are: EGR related maybe? Has new autolite platnum plugs in it gapped at 1mm. I know some cars are very pick on thier plugs. Could this be a problem? Any advice would be helpfull. Thanks!
Old Jun 3, 2013
smajr85's Avatar
Re: p0301, 302, 303, 304 but only when at operating temp? please help!!
Guess i should add it is a 2002 civic 4cyl
Old Jun 3, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Yeah, I would definitely start with replacing those auto lites with OEM plugs and go from there.
PKJ20CR-M11 DENSO
PZFR6F-11 NGK
Did the shop that did the work clean out the EGR passages when they replaced the HG?
Old Jun 3, 2013
Vacuum looks low, is cam timing off by a tooth?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
cferry7
Oct 3, 2015 04:33 PM
srtlat
Sep 17, 2015 11:02 PM
Dave Brabant
Sep 10, 2015 06:48 PM
