Auto tranny problem
Old May 28, 2013
tonkpils1769's Avatar
New Member
tonkpils1769 is an unknown quantity at this point
Auto tranny problem
so i have been having a bit of a issue with my wifes 01 4 door ex automatic.
so to start off one morning we jumped in the car to leave made it about a mile down the road and the car slipped all the way to neutral and would not move. The car would move again if we stopped parked and turned it off and back on it would go back into gear for a few moments then slip back to neutral.
so at this time we had no CELs so i changed the fluid ( replaced with honda fluid ) that did nothing so i assumed the worse and picked up another transmission. After i got the transmission i bought to replace the old one in the car i instantly had a CEL had it checked the only code it threw was "P1706 Open in Transmission Range Switch Circuit" and the car has the exact same symptoms as before so im assuming the transmission was never the problem. Anyone have any ideas?
Old May 28, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: Auto tranny problem
http://engine-codes.com/p0706_honda.html
Old May 28, 2013
New Member
Originally Posted by go-part
Thanks for the info, but I'm still not completely sure if this is causing my transmission to shift terribly and slip into neutral after a few moments of driving. What did you make of the info?
Old Jun 3, 2013
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Any solution to this?
civic__duty
24
Jun 11, 2015 12:29 PM
MajTom
Jun 2, 2015 11:48 AM
bo_red
May 26, 2015 07:25 PM
02Si
Dec 14, 2001 10:26 AM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
