When to replace rear drum brakes
Old May 15, 2013
dakota1820's Avatar
dakota1820 is an unknown quantity at this point
My civic has 122000 on it I believe the rear pads are original. I did check them and they have pad left . I inspected them because I was getting a strange noise when hitting brakes hard going slow like when backing up or going forward at 5mph or less. It's like a creaking noise.... I believe it is from the shoes and hardware on the backing plate probably where one of the friction surfaces are that need brake grease. No biggie isn't hurting anything but when do you guys determine that you should do you rear brakes?
Old May 15, 2013
j_dock69's Avatar
j_dock69 will become famous soon enough
Re: When to replace rear drum brakes
I had that noise and pads since new. I have 360000 kms on my chassis and just changed the shoes a couple days ago and greased everything. Squeak is gone
Old May 15, 2013
GolNat's Avatar
Prelude Owner
Usually back doesn't need to be done until the next front brake job. They generally wear out twice as slow as the fronts, but should be inspected for wear to make sure.
Old May 15, 2013
Twice as slow? Try about 5:1. Five sets (or more) of fronts to one set of rear shoes.
Around here, the original shoes can last the life of the car. Unless someone puts cheap shoes on.
They all squeak when you pump the pedal though, seems like it starts about 75-90k. Needs greased on the backing plate contact pads, 6 per wheel. I like to use Moly grease.
Old May 16, 2013
dakota1820's Avatar
I have some anti seize copper formula would that work?
Old May 16, 2013
Probably for a while, although probably not for a long time as that stuff tends to dry out in a short time.
Old May 16, 2013
mikey1's Avatar
i agree,
i am on my original rear brakes at 250,000km
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Broadbeb
May 14, 2015 09:49 PM
edgenet
Apr 28, 2015 07:49 PM
thesushiboy
Apr 12, 2015 02:54 AM
CivicHX01
25
Nov 18, 2003 09:40 PM
