unusual engine noise
Old Mar 27, 2013
thatownsfinest's Avatar
thatownsfinest is an unknown quantity at this point
sometimes when im driving the car will make a squealing noise. took it to a shop, seems like nobody can figure it out. its not the timing belt its more like a cat wrestling a pig kind of noise. it seems as if it only makes the noise when im in high revvs or if im going at a steady pace and a hill comes up
Old Mar 29, 2013
jimmycivic's Avatar
jimmycivic is an unknown quantity at this point
Re: unusual engine noise
is it standard or auto
Old Mar 29, 2013
beastyben1's Avatar
beastyben1 is an unknown quantity at this point
Belts at correct tension?
Old Apr 15, 2013
unfortunately an auto
Old Apr 15, 2013
is that something i can do myself or am i going to have to take it into a shop to get that done?
Old Apr 15, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Quick version
With the help of the flashlight, inspect the belt and look for wear and tear. If the belt has a shiny or glossy appearance, it will have to be promptly replaced. Slide your fingers across the belt to identify any cracks, torn sections and missing rib sections.
Although a tension gauge is handy, you may use your fingers to check the tension. Press the belt down around the center of the span and make note of the deflection. If the belt can be pushed down more than half an inch, you will have to adjust the tension.
To adjust the tension of the drive belt, use the wrench to loosen the adjusting and mounting bolts. With the help of a steel bar, tighten the adjusting bolt as you hold the tension. You will have to check the tension once again, to make sure that the drive belt has been adjusted properly.
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
silvervtec01
Dec 9, 2001 08:50 PM
