2002 Civic LX, 220k miles. need help.
Old Mar 21, 2013
Civic-LovingMan's Avatar
Civic-LovingMan is an unknown quantity at this point
I've got a 2002 stock civic here with 220k miles.
In the last few days it started acting up.
Wouldn't idle properly and having problems starting
The engine is leaking oil everywhere. I have to add about 1 quart per month.
Anyways here comes the interesting stuff.
I have a CarMD OBD Scanner tool.
I plugged it up and here is what we're getting on the scanner.
P0304
P0300 (.all three related to misfire.)
P0301
Also im getting civic specific codes
P1298 -Electric Load sensor High input?
P1259 -VTEC system malfunction ?
The I/M monitor all are good. But i'm failing on the "check engine light"
CarMD says my diagnosis is to change spark plugs and set valve clearances. (is this a load of crap?)
Main symptoms. Car isn't wanting to idle and it seems to be running poorly.
Leaking oil all over the engine.
I'm going to have the car towed tomorrow.
What are the main things I should have checked?
I don't want to get scammed at the shop.
Thanks guys!
Old Mar 21, 2013
Re: 2002 Civic LX, 220k miles. need help.
If there's oil everywhere, the p1259 is telling you that your oil level is pretty damn low.
P1298 may come or go. Replace the eld unit in the fuse box and call it a day.
Misfires are causing your funky idle.
I'd start by trying to trace the oil leak you have. By "oil...everywhere," where specifically is there oil. That'll help with the Internet diagnosis
Also, pull your plugs, see what they look like. Tips should be a light tan-ish color if everything is copacetic
Old Mar 21, 2013
Ok my uncle came over and we reset the ECM computer chip by pulling the fuse number 6.
The start up was really rough (I think it was recalibrating idle)
and then it started idling good!
We checked with the code scanner and the 1298 is the only code showing
no miss fires and no Vtec problems
the oil is at proper levels.
(its leaking from valve cover we think)
My uncle is coming back over tonight to test the coils with a resistance meter.
What proper resistance should the coils read?
Also how much is the ELD unit?
Thanks for your help man. really appreciate it!
Old Jun 6, 2013
palsana's Avatar
palsana is an unknown quantity at this point
Where is ECM fuse 6 located; under steering wheel or inside the hood? have a pic for it. i have vtec problems & all cylinder misfirings showing up on the codes? this should help a lot?
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
shaejb15
Apr 26, 2015 07:44 PM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
