Screeching noise
Old Feb 25, 2013
Rahway09's Avatar
Rahway09 is an unknown quantity at this point
Screeching noise
hey guys so my car(02 honda civic ex) 4dr sedan is making this screeching noise coming from the hood and my friend says it was an easy fix something to do with some belts the noise happens pretty much every time i turn the car on. can anyone help and tell me how to fix this? please and thanks
Old Feb 26, 2013
mikey1's Avatar
Re: Screeching noise
first you can check to make sure the belts are tight....
if they are, it is most likely your alternator, power steering pump, or a/c compressor
remove the belts and see how well the pulleys turn
start the car with the power steering belt removed, does the noise disappear?
next do the same thing with the alt belt removed, does the noise disappear?
Old Mar 5, 2013
Rahway09's Avatar
i had a friend look at the car and the noise is intermittently but he says the belts are good that its just dust or something of the sort!
Old Mar 5, 2013
If it screeches when you start the car-- then it quits screeching after a little bit, tighten the alternator belt.
Old Mar 12, 2013
Rahway09's Avatar
does anyone have a tutorial on how to do it ? please and thanks also does anyone know how i can fix this like thudding it gets when it rains it sounds like theres water in the wheel well on the passenger side. when my mechanic last tried to fix it he used a ziptide
Old Mar 12, 2013
fsckewe's Avatar
fsckewe is an unknown quantity at this point
Woah, slow down there buddy.
Jack the car up and use jack stands.
https://www.civicforums.com/forums/1...t-upgrade.html
Step 6, 7, 8 and 9 show you where you need to adjust.
Old Mar 12, 2013
Rahway09's Avatar
that seems really complicated ! lol
Old Mar 13, 2013
Scourge of Ages's Avatar
Scourge of Ages is an unknown quantity at this point
I know it looks complicated, but it's actually pretty simple, once you get into it. Just make sure you have the wrenches, and jack it up right.
My car was doing this, and it ended up being the AC compressor / Alternator belt. It wasn't because of the compressor, but the belt is shared three ways, and it was loose.
As for the thumping noise when wet, mine is currently doing that... I'll be interested to see what you get.
Old Apr 21, 2013
Rahway09's Avatar
so i took it to the mechanic and he says the belts are fine and tightened but its still making the screeching noise
Old Apr 22, 2013
mikey1's Avatar
its probably one of your pulleys then....power steering, alternator, or A/C compressor
Old Apr 22, 2013
But no answer as to why there is still a drastically wrong noise?
Your mechanic is broken. Replace him.
Old May 1, 2013
Rahway09's Avatar
so the noise wasnt happening when i took it to him and he was like he needs to hear the noise to further diagnose it but i havent gone back. but i have found that the noise happens more when the ac or heat is on and then when i turn it off the noise stops does that help anyone?
Old May 1, 2013
That's a given. Gotta verify the complaint for ourselves.
However, if you give enough information (which you already have done) one can take an educated guess as to what the most likely cause is:
I still stand by my first reply (clicky): https://www.civicforums.com/forums/p...407-post4.html
(Alternator and AC share the same belt.)
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
