01 civic ex weird probs please help!
Old Feb 6, 2013
Em2andreas's Avatar
Em2andreas is an unknown quantity at this point
Hey guys I'm a little new to the forum I came here in hope of some answers I have 01 ex and I think I'm having a computer problem so I've been told the cars timing belt and sensors were done recently hopefully this has nothing to do with my issue
So the started with a battery light I checked the battery and charging system everything checked out then the next couple drives I got a check engine light for a split second the fuel pump relay would click and a cel would appear this happened for two days and then my tachometer and engine temperature gauge stop working while the rest of the cluster works for fuel and mph which was weird and also had the key light flashing
I tried to read a code and I get no communication to the computer so I took it to a mechanic and he installed a new computer and same problems happen please help if this has happened to you
Old Feb 7, 2013
Re: 01 civic ex weird probs please help!
Alternator bolts were probably left loose when the timing belt was done. This caused a lack of grounding for the alt and excessively high voltage as a result. This burns out the PCM.
Now the next PCM is burned up (again) because the original problem wasn't found and fixed.
If the alternator bolts aren't loose, then carefully inspect both of the ground straps on the engine and transmission. Same situation.
Do a search on this site for 'loose alternator bolts' and start reading.
Old Feb 7, 2013
Em2andreas's Avatar
No way the weird part is when I brought the car back I looked at the alternator and saw the loose bolt it was almost fully out but I thought nothing of it that sounds like it my problem rite there but if I just tighten up the bolt the PCM should go back to normal ? Or would I have to get a new one ?
Old Feb 7, 2013
Tighten the alt. bolts properly.
Pray to the deity of your choosing.
Start it up and see what happens.
If it all works again, then you must have been doing that "good clean living" I hear about. You got lucky. Drive happy.
If it is still all screwed up and acting wrong.....then...well...I already told you the PCM was burned out, so you can expect that.
HTH
Old Feb 7, 2013
Em2andreas's Avatar
Thank you man you've been a great help ill try it in the morning and hopefully all goes well ill post up wha happens take care
Old Feb 8, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
No way
LMAO, you must have had your crystal ball out ezone.
Old Feb 8, 2013
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Poopies
Apr 20, 2017 11:36 PM
shaejb15
Apr 26, 2015 07:44 PM
cdt12271
Apr 23, 2015 11:36 AM
SSMatey
Apr 13, 2015 06:09 PM
