Shopping for ball joints
Old Jan 5, 2013
Acmech13's Avatar
Acmech13 is an unknown quantity at this point
I had my trans rebuilt and was told I need new ball joints. I have an 02 civic ex with around 140k miles. Should I buy ball joints with or without grease fittings? I was looking at the moog mok90332, Ac delco ac45d2310. On auto parts warehouse both appear to be non-greasable. Yet on the amazon review on the moog it appears to have a grease fitting. Which ball joints has anyone replaced their ball joints with? I do get a clunking noise when I hit bumps. I'm about to jack the car up and inspect the other bushings and connectors. I just took over ownership and girlfriend said she has brakes, tires, battery and alternator replaced. So all the rubber bushings may be worn and starting to dry rot.
Old Jan 5, 2013
BIGGS000's Avatar
BIGGS000 is an unknown quantity at this point
Re: Shopping for ball joints
I just replaced my ball joints with MOOG K90332. While I was down there I replaced the bushings in the LCA and the sway bar links with MOOG. The links and the ball joint are greaseable. Multiple people had said the ball joints with the zerk fitting ran into the drive shaft. I don't have that issue. There is a mm or two of room which shouldn't be an issue. The issue that I did find is that when I went to grease them while installed I had to hold the grease gun on the zerk with a decent amount of force to make sure it would go into the fitting instead of all over the place. I've got about 350 miles on the MOOG parts and everything is working great. I had a separate rattling issue that I eventually discovered was just the upper strut nut had somehow gotten loose. Hope that helps!
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
manfredww1
Aug 17, 2015 08:04 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
califcamper
Jul 21, 2015 10:34 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
