2001 Honda Civic Instrument Cluster Lights
Old Dec 25, 2012
kevin2001's Avatar
kevin2001 is an unknown quantity at this point
Question 2001 Honda Civic Instrument Cluster Lights
Hey Guys,the dash lights are not all lighting up, this was after I took out the instrument panel to see what it looked like back their And I took all the bulb retainers out to look at the bulbs and then put them back together and put the instrument panel back together and turned on my light switch and only the top half of the panel lit up the bottom half just remained dark! Like do only certain bulbs work in each socket?? I could use some help
Kevin
Old Dec 25, 2012
CraigW's Avatar
Re: 2001 Honda Civic Instrument Cluster Lights
There are 5 neo-wedge bulbs total. Replace them all at once.
Old Apr 20, 2013
pnamajck's Avatar
pnamajck is an unknown quantity at this point
i'd suggest you take her down again . . . take out each bulb . . . place that bulb in again . . . make sure you rotate each bulb.
LionSpratt
Jan 29, 2017 11:07 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
