Camshaft Seal
Old Dec 8, 2012
Rem7mmMag's Avatar
Rem7mmMag is an unknown quantity at this point
Camshaft Seal
Does anyone know of a "how to" for changing the camshaft seal? I have a Hanes manual but it only refers to replacing the camshaft itself. I just want to replace the seal because I believe that it is leaking oil.
Its a very small leak and its not enough to make the oil level go down. However it is enough to get all over the engine and make spots on my driveway.
It's a 2001 LX btw.
Old Dec 8, 2012
GolNat's Avatar
Prelude Owner
Re: Camshaft Seal
Just pop it off with a small flat head screw driver, and pop the new one in.
Old Dec 8, 2012
Rem7mmMag's Avatar
Re: Camshaft Seal
thanks I did find a video if anyone else has this problem:
Old Dec 11, 2012
toucansam333's Avatar
toucansam333 is an unknown quantity at this point
Re: Camshaft Seal
You have to remove the timing belt for that. How do you know it is the cam seal? Would be difficult to know if it was from there since it is all covered up. Where on the engine is it showing up?
Old Dec 11, 2012
Re: Camshaft Seal
toucansam, there's two ends in the cam. He is asking about the easy one, not the hard one behind the cam gear
Munzy
21
Oct 7, 2015 07:48 AM
Elciteeve
Sep 28, 2015 12:40 PM
Sep 27, 2015 11:33 AM
Rexall
Sep 11, 2015 02:30 PM
Chameleonman
Bolt-on Engine Performance
Sep 5, 2015 04:06 AM
