Engine sputtering/CEL light clicking
Old Oct 5, 2012
Radianceautospa's Avatar
Radianceautospa is an unknown quantity at this point
Hey guys.
My civic developed a wierd issue on the highway and I was forced to tow it home. When I start the car the civic sputters as it sputters the check engine light blinks on and off and a I hear one of the 4 relays under the glove box clicking , After about 1 minute the tach dies and the sputtering goes away , but it wont rev up and it feels as if I've hit a fuel cut. I also can no longer run the OBD codes because none of my 3 readers can communicate with the ECU. I have repleaced my PCM , Checked the grounds under the bumper . PLEASE HELP!
Old Oct 5, 2012
Re: Engine sputtering/CEL light clicking
I forgot to mention . The new PCM had been programmed to match my key . The swapping of the PCM made no difference
Old Oct 5, 2012
See if the alternator bolts are loose.
Are you a shop? Pay for ALLDATA. The info should be there.
EDIT: The info IS there.
Old Oct 6, 2012
Whats alldata? I was unaware a loose alt bolt could cause this I will check when im home.
Old Oct 7, 2012
Checked for loose alt any more suggestions?
Old Oct 7, 2012
Your code readers worked with this same car prior to having this problem?
You've described a 7th gen Civic that is repeatedly burning up PCMs.
I assume the description is true, no?
Monitor system voltage.
Excessive voltage burns up the PCM.
Somewhere over about 16 volts will start killing it.
Loose alternator hardware is a known and documented cause of this, there are service bulletins telling to look for this as a cause (ungrounded alternator, maybe an ungrounded block too).
A bad alternator could cause the same thing.
HTH
Old Oct 10, 2012
Correct I had recently replaced a dying alt. After replacing I still had a battery light. A volt meter showed 14.2 but my scanner showed 13.0 I was unable to diagnose this issue. My temp guage was also malfunctioning .The next symptom was the car dying. I am planning to get a new pcm and try to communicate with it without having the alt connected . Any suggestions?
Old Oct 10, 2012
Originally Posted by Radianceautospa
Correct I had recently replaced a dying alt. After replacing I still had a battery light..........
Any suggestions?
Sure....Don't use discount reman alternators.
Verify the wiring isn't a problem.
jetcare101
May 8, 2015 01:33 PM
Dorval Andre
May 1, 2015 09:37 AM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
supercivic01
South
Nov 30, 2001 11:27 AM
