2003 civic ex timing belt question
Old Sep 11, 2012
Honda310's Avatar
Honda310 is an unknown quantity at this point
great forum and I know there is a lot of talk about the timing belt replacement. Before I put the covers back on I think I did a shortcut by mistake. The tensioner I did not understand at all. I loosened the bolt and detached the spring to remove the belt and did the same to installed, I put the spring on and tightened the bolt. I did not under stand the granade pin but if I have to do I'll remove and try it. Belt seems tight, help!
Old Sep 13, 2012
04 Honda Civic's Avatar
Re: 2003 civic ex timing belt question
https://www.civicforums.com/forums/1...t-diy-2-a.html
Check that out. Specifically steps 20a-28.
Old Sep 18, 2012
mikey1's Avatar
use the grenade pin method, do it properly, you dont want to be taking chances with the timing belt, its not something to gamble on, i just changed mine yesterday!
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
Blaster30
Apr 22, 2015 12:21 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
