02 Civic Si -Loss of Power
Old Aug 17, 2012
fadn12641's Avatar
fadn12641 is an unknown quantity at this point
My 02 civic Si Veloz very suddenly lost power. The cold air intake is louder than usual, so loud that I thought the exhaust pipe was the issue. I can only accelerate to 3300 rpms before the engine begins to decelerate(even with the gas pedal to the floor). I have to downshift(sometimes down to 3rd or 2nd gear) to get up a hill. The exhaust note at idle speed sounds like the grunt of a muscle-car, not smooth like it once was. I don't know the engine code, but it indicates there's a problem with the MAP sensor. It and the idle sensor were replaced to no avail. That code went away, then came back. Mechanic says the cat converter is okay. The transmission, clutch, timing belt and fuel pump were replaced 4-5 yrs ago. Sometimes when I drive with a cold engine, all symptoms disappear and it runs smooth as silk(only for a minute or so). Any idea what the problem is?
Old Aug 17, 2012
BlueEM2's Avatar
Whachya lookin at?
Re: 02 Civic Si -Loss of Power
You need to clean the throttle body. The intake valve is probably sticking on crap and not flapping properly. Among other dirty things.
Old Aug 18, 2012
scooty's Avatar
scooty is on a distinguished road
Catalytic converter is clogged.
Old Aug 19, 2012
fadn12641's Avatar
The throttle body has been cleaned. When I disconnect the idle sensor it runs better, but jerky enough to induce whiplash.
Jonnie.
Jan 13, 2019 11:21 AM
bsmiley
Apr 27, 2015 01:27 PM
darwin-t
Apr 18, 2015 09:29 PM
SSMatey
Apr 13, 2015 06:09 PM
LexBoy
Nov 5, 2001 08:00 PM
