cooling system
Old Aug 7, 2012
02 civic sorrel's Avatar
02 civic sorrel is an unknown quantity at this point
cooling system
i recently bought an 02 civic and i'm having a cooling issue. here it goes i noticed the temp guage climbing on a drive so i assumed it was the thermostat so i flushed the cooling system replaced the thermostat filled the cooling system put the cap on loosley ran the motor at 1500rpm until cooling fans kicked on twice then filled radiator rest of the way and filled reservoir to minimum line my temp gauge starts to climb after 40 min of driving upon inspection the system seems to be pushing the coolant into the reservoir to the point that it overflows out of the reservoir
Old Aug 7, 2012
sl33pyriceboi's Avatar
Re: cooling system
you prob have air bubbles in your system. park on a hill facing upward and let the car run. the steeper the better.
and when you changed your thermostat, did you use OEM or aftermarket. always use oem...
you should have changed the gasket as well when you changed the thermostat
Old Aug 7, 2012
Re: cooling system
Moved to the correct section
Old Aug 9, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Re: cooling system
Pull the rad cap and run the engine until it gets "hot".
Are there air burps/bubbles in the radiator?
cukaracha
30
Jul 26, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
hayden55
Jul 8, 2015 11:38 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
ZILLA
Jul 5, 2015 05:24 PM
