Freon lines
Old Aug 2, 2012
civicinin's Avatar
civicinin is an unknown quantity at this point
Freon lines
I am removing my a/c compressor. My question is, when I take out the a/c compressor, should I disconnect the freon lines? Should I disconnect them right at the a/c compressor, or should I disconnect them right under the hood (see the part circled in black below)? Also, will the lines seal automatically when I disconnect them?
Thanks.
Old Aug 2, 2012
GolNat's Avatar
Prelude Owner
Re: Freon lines
The object you circled in red is the power steering pump. According to the service manual you are suppose to disconnect from the condenser which is in front of the radiator. You are also suppose to use a refrigerant recovery/recycle station.
Old Aug 3, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Re: Freon lines
Why are you doing this?
Old Aug 3, 2012
civicinin's Avatar
Re: Freon lines
My a/c compressor is needs replacing, and I don't want or need a/c, so I'm taking it out.
Old Aug 8, 2012
civicinin's Avatar
Re: Freon lines
A follow-up question. I took the a/c compressor out, and now my car won't start without a jump. I know the new shorter belt goes to the alternator alone now. Could it be too tight or loose? Any thoughts?
Old Aug 9, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Re: Freon lines
What is the resting voltage of the battery? Key out, lights/stereo off.
Grab your multimeter and post voltage.
The belt could be too loose.
jackoncruzpr
Sep 29, 2015 07:59 PM
Hutch1051
Sep 29, 2015 09:20 AM
powman02
Sep 15, 2015 07:38 PM
BJB
Sep 14, 2015 11:16 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
