fuel gauge issue
Old Aug 6, 2012
em2maxamillian's Avatar
em2maxamillian is an unknown quantity at this point
fuel gauge issue
I suspect it is the sending unit, but I wanted to run it by forums to see what others had to say. On my way home, I noticed that I was low on fuel. The gas light came on. After refueling, I got into the car and started the engine. The fuel gauge remained near empty. After 20 minutes of driving, it finally made it to full. I checked the gauge cluster using the sweep test and the fuel gauge moves without problem. If it is the sending unit, would I need to replace the entire fuel pump assembly? In other words, is the sending unit a part of the fuel pump itself or can it be replaced seperately? Thanks guys!
2004 ex 5 speed 4 door
Old Aug 6, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: fuel gauge issue
Excellent question. I do not know, but from the drawings I've seen, it looks as if the float assembly is attached to the fuel pump. I'm not 100% on that. I would go to a local dealership parts department and ask if you can order/find just the fuel sending unit itself.
Only info on parts for area linked below.
http://www.hondaautomotiveparts.com/...L+TANK+%281%29
Good luck.
Old Aug 6, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Mine has been the same way for the last four years since I have owned it (2001 LX).
I think it is simply due to the pressure difference leveling out after the fuel cap is removed/installed.
I did replace the fuel cap recently due to a leaking seal and broken clutch but I have not been able to monitor the fuel level after fill because it's my wifes' daily car.
mistermenphis22
Apr 3, 2016 08:06 AM
Allecr3
May 22, 2015 01:24 PM
werdnahall
May 17, 2015 11:37 AM
McD
Apr 29, 2015 03:50 PM
htowncivicEX
Jan 21, 2002 11:48 AM
