A/C Valve
Old Apr 29, 2012
scot0410's Avatar
scot0410 is an unknown quantity at this point
A/C Valve
Does a 03 Civic EX have a valve for the temperature adjustment? Similar to this one.
http://www.odyclub.com/forums/showthread.php?t=154166
It is in post #6. Sorry I had to post from the Honda Odyssey forum, but I couldn't get just the picture to post.
Thanks in advance for any help!
Old Apr 29, 2012
Re: A/C Valve
Similar, and yes. In one of the heater hoses.
Pic from your link:
Old Apr 29, 2012
scot0410's Avatar
Re: A/C Valve
Thanks for the pic. Anyone know the location of this? What hose?
Old Apr 29, 2012
Re: A/C Valve
Open the damn hood and look!
Engine compartment, very close to the firewall where the heater hoses go through.
Was this helpful?
Old Apr 29, 2012
scot0410's Avatar
Re: A/C Valve
Yeah. It was helpful, thanks. The hood has been open as I am doing some work. Rotors pads and brake fluid flush.
Old Apr 30, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Re: A/C Valve
That's the heater valve.
Is yours leaking?
Old Apr 30, 2012
scot0410's Avatar
Re: A/C Valve
Is yours leaking?
Not leaking. Just wanted to make an adjustment if needed.
Old May 1, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Re: A/C Valve
The only adjustments available are to tighten the ball valve screw that is covered in green or the cable slack adjustment that can be seen to the left where the cable is clamped to the bracket.
Old May 1, 2012
scot0410's Avatar
Re: A/C Valve
It's the cable slack adjustment that I wanted to check.
Old May 3, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Re: A/C Valve
Turn the temp **** to full cold and the arm on the valve should be at 90* to the valve body. Turn the temp **** to full hot and the arm should be directly centered with hose connection.
Check for excessive movement at both full hot and cold settings and adjust accordingly.
Nathan
mcollins
Electrical
Jul 27, 2015 10:59 PM
cukaracha
30
Jul 26, 2015 12:01 PM
cukaracha
Jul 23, 2015 08:50 AM
Jul 14, 2015 03:39 PM
ZILLA
Jul 5, 2015 05:24 PM
