Messed up engine
Old Apr 11, 2012
Eldondedr's Avatar
Eldondedr is an unknown quantity at this point
Messed up engine
I have the D17A2 engine, and I followed the torque specifications which where 14, 36, and 49 lb/ft for the head bolts, and 14 lb/ft for the rocker arm, so when i started the car it was turning over but not starting. After disassembling it again, I noticed anti-freeze and oil mixed in the head, meaning it wasn't tight enough. How did this happen? Is the above not the correct torque?
Old Apr 11, 2012
BlueEM2's Avatar
Whachya lookin at?
Re: Messed up engine
That's the correct torque. Did you torque it in the right sequence? If you did, and it still does not seem too tight there is a good possibility that your head is warped so you may have to over torque it so that they mate properly. It's not an ideal solution, but it might work.
Wild Cranker
427
Jan 28, 2016 06:49 PM
juror
May 26, 2015 06:35 PM
dragonsblood
Apr 27, 2015 12:28 PM
DC5@EM2
26
Jan 22, 2002 10:44 PM
Aznnp77
Jan 8, 2002 04:04 PM
