help needed ! instrument cluster dosent work :(
Subscribe
Feb 26, 2012
hello i just received my 2005 manual cluster , from a Honda Civic 5MT EX (SPECIAL EDITION) 2 door 2005 , for my 2005 honda civic LX MT 4 Door , i hooked everything up and cluster is just dead nothing would turn on ? is it possible that the cluster itself is broken ? how can i check if my new cluster is working ? and any diagnosis available ?
Reply 0
Feb 26, 2012
Re: help needed ! instrument cluster dosent work :(
Fuses?
When you purchased the new gauge cluster, is it the same part number as the old? The LX and EX are different in some ways. The EX has things that the LX doesn't. SRS for one. so wires could be going to the wrong places.
Reply 0
Feb 26, 2012
Did the old one work?
Why on earth would you do this if it worked?
Why did you get a wrong unit?
There are at least a dozen different gauge cluster possibilities.
Not all of them work the same.
Reply 0
Feb 26, 2012
well the RPM and the speedo and the temp on the old one werent working :P that was a good enough reason to get a new one , and i bought the stock one off an EX 2005 manual .
well i hope its wires i just read a DIY about splitting the wires , i ll try it tomorrow thank you
Reply 0
Feb 27, 2012
:SMH:
Reply 0
Feb 27, 2012
Quote:
Agreed.
This isn't going to turn out well.
Reply 0
Feb 27, 2012
I can see it now:
Quote:
So, i did the DIY and i don't understand why my new cluster isn't working still. Does anyone have a wire diagram for a 2005 LX gauge cluster? I'm just going to order the right one for my car now....
Reply 0
Feb 27, 2012
Quote:
I can't afford to order the right one for my car now....
Fixed.
Reply 0
Feb 27, 2012
am sorry for the waste of time guys the cluster is working properly now again am sorry because am new in the DIY thing .
Reply 0
Feb 28, 2012
Glad you got it going
Reply 0
Feb 28, 2012
yeah man, good job. Don't worry about Ezone and I, we can get carried away sometimes. but we mean well..... Sorta....
What did you do, post it so anyone else who may have the same problem can see what to do.
Reply 0
Mar 2, 2012
no problem man well i guess i messed up some wire connection no big deal i think because the gauges are working perfectly thanks to Blueem2 , i am new to the forums and new to hondas since this is my first :P i have read a few DIY and am attempting a turbo timer install and a spark plug change later today thanks again
Reply 0
Subscribe
